Hello there
I 'm using a local sync for a looper patch.
I tried to change the metric of this local sync but I can't ...
Using a sting to comma text I entered 6/4,6/4 in bar list (I see it when looking at my local sync)
but still the local sync shoes (and act) 8 beat per cycle and ignore my bar list
I can change the tempo but not the bar list.
what am I missing ?
Hope you manage to enjoy this time
Local Sync
Local Sync
- nay-seven
generally, you can use the comma text output of a listbox, but you're right, maybe a bug here
will check
will check
My method seems to work on the master sync
- nay-seven
solved on next release
thanks
I have to say I'm happy the problem didn't come from me
