Hi
I made a patch witch generate several random midi notes with different pitch and velocity
The pitchs are good but the velocities seems to be added. Is it possible to separate each velocities as when i play with a keyborard or piano roll ?
generate a polyphonic midi message
- senso
with the mouse + [shift] on the midi note to adjust the velocity
use a "midi create message module" with random on code1 and on code2 ?
