So I had a script in V5 with a set of parameters driven to internal arrays ( a real parameter, but not visible), when storing a a preset manager the array would store/recall what was saved
now im trying same script in HH and i don't get the recall, even tho ive set the arrays with "SetdontSave, memoArray, FALSE"
any clues?
Store-Recall Script Datas from PM
- nay-seven
Sorry for later answer, have you find a way ?
no pb nay^^.
i didn't retried in HH3, but seems it has been changed behavour since HH1, scripts are no more compatible with pm, only 'UI items are.
it's a bit sad and complexify a lot things imo, i wished scripts kept this behaviour, having them as not saving/recallaing datas by default for ex , unless precised otherwise if creating problems for ex.
but told olivier... hope may be back in the futur
