Page 1 of 1
Posted: 18 Jun 2016, 16:54
by Shintylla
Is there a specific module for creating random data from physical movement(like balls inside a square)?
Ale
Posted: 18 Jun 2016, 19:56
by nay-seven
Yes, the Draw XY panel and the XY Pad in the modules/interface design.
you can then activate the physics engine in the settings panel/size tab.
Posted: 18 Jun 2016, 20:34
by Shintylla
