latency problem, need help understanding...
Pianoscope
Unread post by Pianoscope » 22 May 2016, 23:01
Im trying to figure this out.
Lets say I have two racks.
Track one is a drum loop, track 2 is set up as a standard AUX send. (track 1 output > track 2 input)
I insert a plugin with latency on track 2, Eventide’s Omnipressor. This adds 0.7 ms of latency.
Comb filtering and phase cancellation appears, which tells me the 2 racks are no longer sample aligned.
I have tried to add a simple mix knob to the plug in patch, and get the out of sync result.
Is there a way to force Usine to acknowledge latency and adjust globally?
This latency issue also happens with sound toys, which all add 0.7ms.
Am I not understanding how Usine handles plug in latency?
Pianoscope
Unread post by Pianoscope » 22 May 2016, 23:06
The solution I found is to add the latency manually using the delay module.
But I would like clarification as I am getting a lot of phase and comb issues using multiple microphones.
