In a sampler I would like to change the sounds in the list, while keeping the loop playback.
The problem: when I select a sound file via a preset, the playback stops.
The function play/stop can't be changed in play/replay.
The function loop remains if I use the keys back & before in the list (top right of the sampler), but I don't want to be constrained by the order of the list, I'd like play go the file / preset 1 to the file / preset 4, for example.
Would you know how to do?
Thank you
Gw.
sampler, loop & presets
- nay-seven
sorry for this late response
if you create presets with the preset manager, and assign Midi or key learn to this preset manager numbers ?
