just bought this wondefull midi interface and wonder if it's possible to send all my cc midi value when i load a workspace...?
i've saw that for example , it's possible to use the " create midi " module to send value to the brc2000
there's also the "remote " function in the global remote window but seems to be reserved to motorized controllers...?
possible or not...?
any suggestions..?
usine and brc2000
- nay-seven
- senso
I use a BCR2000; it's my main midi interface.
The BCR is, in fact,a kind of motorized controler.
So no problem to do that.
Make a midi learn on a Usine fader, then
1)go to file/setup/midi out
2)activate the midi out of you BRC
3)switch the remote option of the midi out ON
that's all
Usine does everything
Now if you move the fader with the mouse in Usine it also update the position in the BCR every second.
that's all
- nay-seven
whooo
really love Usine.....
Many Thanks Senso !!!
