Midi2OSC
Ken29
Unread post by Ken29 » 03 Jan 2016, 00:23
Hi Guys,
I intend to turn an old Sony DMX R100 (digital desk with midi functions) into a super remote for Reaper. Usine is used to change the Midi CC into OSC signal. It works pretty well when I move on fader at the time but it doens't when I move two.
Here's a part of my multivoice sub patch. When Midi in CC code 1 is "1" it goes to OSC usine/volume/1, "2" goes to OSC usine/volume/2, etc...
My guess is in my patch, I can only filter one Midi signal during a block, and it is always the first one, so only one OSC address goes out. (and that's what I see when I trace).
The question is how could I separate the different midi signals simultaneously in a same block toward the different OSC adresses ?
Kenan
Unread post by oli_lab » 03 Jan 2016, 15:07
try using the receive output from the midi module into the send of the osc send
Ken29
Unread post by Ken29 » 03 Jan 2016, 16:54
Thanks Oli,
Hum, I'm trying to figure out your proposition but without any filtering, whatever the CC channel, all the incoming datas will go out to all the OSC addresses at the same time.
I have 48 faders and 48 pans and each one has to go to a single OSC address.
Ken29
Unread post by Ken29 » 03 Jan 2016, 22:50
I found it ! So simple : I used the unpack option of the midi input...
I love Usine !!!
Kenan
