The matrix display or set module can only set one colour per row or column, see http://www.sensomusic.com/wiki2/doku.ph ... ers:matrix
However, the old Matrix Pack by Martin Fleurent could show different colours across all cells, see http://www.sensomusic.com/wiki/doku.php ... matrixpack
*** Is is possible to set colours across all cells in the matrix display or set module ?
I was also surprised that the fader inputs were not combined into a data array, but I suppose they can be combined using an array module. However, an array could be an easy way to allow colours to be different in all cells.
On the other hand, a disadvantage of an array would be that the individual values cannot be seen on the parameter editing screen (at least that seems to be the case with array parameters in general).
Simon.
- nay-seven
This module is a user module and was updated and simplified for Usine Hollyhock II and Mac compatibility, so not the same features than the old 5 version.
