restart when file number changes
joffo78
Unread post by joffo78 » 06 Dec 2015, 23:09
On the sampler if i change the file while is playing the position restart. Is it possible to have a continous loop even i change the file number ?
Unread post by senso » 09 Dec 2015, 10:20
actually no option for that.
a simple patch can do the trick with 'wait' module
- memorize the reading position
- make 'stop' on sampler
- change the sample
- apply the memorized postion
- make 'play' on the sampler (with auto restart off)
senso+++
joffo78
Unread post by joffo78 » 10 Dec 2015, 07:44
Ok thanks a lot ;)
jf
