Page 1 of 1
Posted: 17 Oct 2015, 22:23
by Shintylla
Can anyone tell me how assign a midi command from an external midi pad for passing from one track to another while recording?
THX
Posted: 18 Oct 2015, 00:34
by sephult
I think they are not wired to do so. Not 100% sure, but last time I looked I don't think the patch was made to do it that way.
I am thinking about modifying it that way to work with my Art X-15. In the past I had a patch but lost it.
If I come up with anything I will share.
-s
Posted: 18 Oct 2015, 16:12
by sephult
Test RC5_1
Here was a test version I made several weeks ago, havent had time to double check, but I added Rec/Clear for each besides the master.
Seems the Master still works like the RC5_1 along with.
Well I edit...I just tested and I see why this patch might not be compatible and needs more modification.
I think it depends on the sequential numbering, so I think if you record out of order it doesn't play right.
Also I think there are some other bugs that need looked at. I have a little time I might spend today on if I get anything I will share.
But regardless, the patch will need modification to be all separate loopers, in this case I might rebuild.
-s
Posted: 18 Oct 2015, 18:40
by sephult
Try this one, it removes the sequential RC51 increment, but setup for triggering on whatever one you want.
Each has individual clear, and mutes.
Test RC51-2
