i try to build a patch with 4 samplers. Each one should have the possibility to load different sample. i want to create 4 differents sample list, and have the possibility to choose the sample to play for each sampler.
I try it with the polyphony method.
But i didn't know how to load my 4 differents Sample list in each sampler ...
i made a patch with text module to explain. It work but now i need to replace the 4 text module with the 4 samplerList and show them only with short name ...
thank you
My patch is here 4-Players Patch
polyphony and different sample list
- cmodica
I will try it soon.
see you
I will try it soon.
see you
