Modification of an existing module
hegeldas
Unread post by hegeldas » 26 Sep 2015, 15:05
Hello, have to cook a surround perf on 12 output and would like to modify the existing module that allow ....8-16... output, is it possible to change the default settings to 12 outpout
Akis
Unread post by Akis » 26 Sep 2015, 21:26
I thing just take a module with 16 output and reduce to 12 in the popup windows.
sephult
Unread post by sephult » 26 Sep 2015, 22:16
You can always select a module and click recreate from the context menu on the left side.
This will bring the original prompt and adjust the module.
-s
Unread post by nay-seven » 01 Oct 2015, 10:35
no, the 12 outputs is not proposed by default in the pop up window ( not easy to propose 2 up 64 step by step)
so as said fournier, you need to use a 16 outputs version , and reduce to 12, but in the module directly
