Page 1 of 1
Posted: 01 Sep 2015, 04:26
by CREDO
The new quick links seem pretty cool, but it's still a bit unclear how they work exactly. It says they can't connect between Racks, but what about patches in the same Rack? And is one block of latency always added, or only under certain circumstances?
Thanks!
Posted: 01 Sep 2015, 07:04
by sephult
Hi credo!
They do not send/receive across multiple patches in a rack.
However, they do work within a patch. This includes quick-links within sub-patches.
This is a huge step for patches with big wiring nests (lol most of mine), allowing a cleaner wiring scheme (and probably much easier to understand).
-s
Posted: 04 Sep 2015, 21:35
by CREDO
Thanks sephult, that’s what I thought. The
documentation only says racks though, so I wanted to be sure : )
Maybe it should be updated to say “can’t communicate between
patches or racks” (instead of just racks) and “
will be delayed by one calculation BLOC.” (instead of can) – or am I missing something?
Posted: 09 Sep 2015, 01:43
by sephult
I will have to update this soon, I agree credo.
