Page 1 of 1
Posted: 22 Aug 2015, 16:38
by oli_lab
anyone here has done some fuzzy logic controller with Usine ?
I'm building a expert system to control a music machine,
any input welcome
Posted: 03 Sep 2015, 13:33
by XpiR
Hi Oli
This not an answer, but if you go ahead into fuzzy logic please don't hesitate to share, I'd be quiet curious to know how you use it and how you implement it with Usine...
Posted: 03 Sep 2015, 15:09
by oli_lab
So far I did some research and learning, but put it to an halt as I have to finish my current project and choose a different approach.
But for what I can imagine, fuzzy logic could be very musical as it is doing the same as a composer : making decision.
My first Idea was to have 2 input parameters to command a big compositionnal device that has 10 inputs,
my next go will be to make a sampler reader servo-driven by physical sensors.
Posted: 12 Sep 2015, 18:41
by oli_lab
here is my first attempt at fuzzy logic.
http://www.sensomusic.com/forums/upload ... li_lab.patfuzzy logic patch 1
up to you to use 2 variables as inputs and you'll get an output to control whatever pleases you !
keep me updated
Posted: 12 Sep 2015, 18:49
by sephult
Looks cool, but unsure how it's supposed to work. Can you give more explanation into it?
Posted: 13 Sep 2015, 00:50
by oli_lab
I'm still trying to imagine a use for it...but I KNOW it is a good idea !
just try to think when you need to control the speed of a sampler...
