Page 1 of 1
Posted: 22 Apr 2015, 03:01
by ahonoe
Looking to get rid of the on/off LED in the top right corner of my patch headers. Can anyone point me to where the property is to do this, or the IML?
Posted: 22 Apr 2015, 04:00
by sephult
I only know how to do by disabling the header itself. That is about the only way I have found so far.
Posted: 22 Apr 2015, 08:45
by nay-seven
yes, but you can keep the header and disable only the header toolbar in the settings panel/design tab
Posted: 22 Apr 2015, 23:33
by ahonoe
Yes, the problem is that I want the maximize/minimize button. When I turn off the toolbar, that goes away. Strange... I swear I was able to do this before.
Thanks anyways.
