Preset Manager in last versions
daviche
Unread post by daviche » 01 Apr 2015, 08:42
Hi guys,
is anyone experiencing troubles with the preset manager in the last versions ?
I can't recall properly my presets... (preset manager is located in my workspace)
DC
Composer - guitar player
Dell INSPIRON 16 5645
Windows 11
RME Fireface UC - EVO 8
sephult
Unread post by sephult » 01 Apr 2015, 09:08
I had some but I believe were related to my patches.
When you mean preset manager located in my workspace....by which are you talking, like the Rack preset manager?
-S
daviche
Unread post by daviche » 01 Apr 2015, 09:38
The preset manager I use is located in the workspace, not in a rack nor in a patch. So, it's a "global" preset manager.
And this workspace works fine - including the preset manager - on Hollyhock versions before the v2.
Windows 11
sephult
Unread post by sephult » 01 Apr 2015, 17:28
So is this a preset manager and you just set the target to workspace then?
This is one you placed the module in a patch previously?
I assume you might want to check the differences between the HH1 and HH2 Preset Manager module.
Maybe replace the module with a new one from the HH2 Module Library.
There is the new additional workspace, so maybe something changed in how the module works.
The difference maybe was not noticed with patch/rack as the target...but possibly workspace is causing issues because of changes.
-S
