The switch module has a gesture output, type array. I have connected this to an array input parameter in a script, but I only get an array length of 1 with value 0 however I swipe over the switch.
I also notice that the trace panel describes long / short single / double hold, but no pan as indicated in the manual.
Does gesture work in Hollyhock version 1 ?
Simon.
gestures in fastscript
sephult
http://www.sensomusic.com/wiki3/doku.ph ... []=gesture
Just updated, tutorial on touch and gesture.
Did you enable trace gestures in the Setup Panel?
-S
-S
Yes, trace gestures is enabled, and I get array parameters for the X and Y positions to indicate multi-touch. But nothing on the gesture parameters.
It is Usine Free upd11 1.1.0009g Win32.
Simon.
Simon.
