FastScript - For i:=0 to lngthMidi-1
sephult
Unread post by sephult » 06 Mar 2015, 18:58
Hello Everyone!
I am running into some strange issues with the For loop.
Up until this point I have used bigger sized messages, and it seems at this point there is a bug in the For loop.
If I set the lngthMidi equal to 1 it should essentially be the same as below:
Code: Select all
for i:=0 to 0 do begin
end;
However, even though it is supposed to be only 1 iteration of the loop it looks like it is running 2 iterations of the loop.
Curious I was wondering if anyone else has run into this?
sephult
Unread post by sephult » 08 Mar 2015, 16:23
I did get around this I had to use an additional, conditional statement with a break...it just seemed odd that this would present 2 iterations.
