Audio transition using the grid
pshd22
Unread post by pshd22 » 05 Feb 2015, 12:48
Hi everybody
I progress in the exploration of Usine Hollyhock and its possibilities, I build 15 different tracks to a 6/8 score with 6 whole notes frames with harmonics variations.
For each variation I have a track with midistep module and 6 steps. this module send midi notes to a VST plugin embedded in each track.
In the end I use the grid and fill 60 lines for a sequence of these tracks.
Problem or questions :
when the grid is playing, audio transition is not very clear, the score is arpeggio of whole note, the result is sometime a chord of 2 notes just at the transition between line of the grid,
this phenomenon persists regardless of the tempo.
this phenomenon persists also when the VST plug in is embedded in the patch or out of the patch in the same track
The patch is very simple : the midi out of the stepmidi connect to the midi in of the vst plugin.
I tried to send allnoteoff at the end of the sequence : one module A=B A connect to num of step, B connect to pos of step, the exit connect to input of allnoteoff, but the result is not good.
It's better if I the out of each track is connect on the same midi bus, this midi bus connect to one VST plugin.
But sometime there is a delay
do you have idea for the best patch configuration ?
the processor is intelCore 2duo P8400 2,26 ghz
6Go RAM,
Windows 7 64 bits
Pascal
Unread post by nay-seven » 12 Feb 2015, 22:21
sorry for the delay, but as explained by mail, we need a workspace example, cause we don't know how is the synchro of the step module, how you create your grid and options chosen..so please provide a workspace.
you'll discover that they are always many ways in Usine
