Posted: 06 Dec 2014, 15:26
This procedure (SET_TARGET_PATCH) rises some questions.
The manual says: "Define the target patch which will receive Internal Messages".
1. What happens exactly if more than one patch (or more generally, subpatch) has the same name in the workspace?
subsequent question: is it possible to give to a patch a name different from the one displayed as caption in the caption bar? or name=caption?
2. It seems that the internal messages send with a 'Send Usine Internal Messages' module are only received by the patch where the module is, whatever any 'SET_TARGET_PATCH' procedure has set just before in the message (except of course using the 'SENDER_PATCH' variable). Do I misunderstand its use, or its syntax, ore something else? Or does it work for some procedures and not for some others? Or does it really have some effect?
Thanks!
Best regards,
Vince
Thanks!
Best regards,
Vince
