Seems I cannot get more than one iFFT to work in a patch.
The second one never seems to convert the audio.
Anyone else have this problem?
iFFT Bug?
- senso
non confirmed.
try to isolate the pb and post a bug report?
sephult
Thanks senso,
I think I keep running into iFFT and inverse Phase Vocoder corrupted in my module library.
It started out working the other day, I got crazy patching and seemed to just go downhill from there.
I will isolate and get more info first.
-S
-S
- senso
are talking about ifft or iPhaseVocoder?
they are different
they are different
sephult
Actually, started out ifft gave me problems.
I was patching with it, and had two copies in a patch doing left/right audio.
The second one was not working. Now I cannot get to work at all.
I was also again playing around with the iPhaseVocoder.
Then I ended up back in the same boat I was in awhile ago where the iPhaseVocoder from the module library was not putting out audio.
Currently both modules, ifft and iPhaseVocoder directly from my installation directory will not output audio.
First I've had with the ifft, but I do recall my previous problems with iPhaseVocoder.
I did remember a bit
Yes the Pitch Shifter Patch works, the iPhaseVocoder and iFFT module from the library do not.
-S
-S
sephult
Well the iFFT I think I got sorted.
Even though it states size 1024 - 512/512 it is not outputting
If I just make a change and go back to 1024 size it kicks back on and audio starts playing.
Noticed decreasing my bloc-size believed to help as well. Nothing less than 1024 at 256 block size worked.
For the iPhaseVocoder, I replaced the module in the library with a fresh extract and still no output.
However, changing my bloc-size from 256 lower and then setting back to 256....it now works!
-S
-S
