Smooth freeze clic
Unread post by cmodica » 10 Oct 2014, 16:04
I try to use ''Smooth Freeze"" Patch to make an infinite sound. So i record in live a short part of the instrument resonance, 350 ms for example, and play it in loop with the ''Smooth Freeze"" Patch.
it works well but there is a clik when the sound loop ... The sound is 350 ms long, so there is a lot of clik !
Is there a way to do that without this clik ?
thanks.
joffo78
Unread post by joffo78 » 10 Oct 2014, 19:24
can you manage to do that with this patch ?
http://www.sensomusic.com/forums/upload ... freeze.pat
Unread post by cmodica » 11 Oct 2014, 15:42
Yes Thank you. I have test it just now and it seems to work without clik :D
Congratulation, you are a master !!!!
We have a rehearsal on monday and i will test it in live condition.
Thank you very much !!!!!:lol:
I will take a look later to this patch and try to understand.
i will tell you about my experience in live. Thank you very very much.
Unread post by cmodica » 11 Oct 2014, 16:10
I test again. it seems perfect but it stop after a lap time and seems to sample an other part of the sound ...
But if i mute the input it keeps the sample and never stop ...
Is it true or is it a bug ?
Unread post by cmodica » 11 Oct 2014, 16:30
Sorry. i understand, it is a realy nice patch !
There is 4 options for the sound detection: env follower, beat follower, frequency change and Off. If i set it to Off the freeze sample never stop nor change.
Is it ok ?
joffo78
Unread post by joffo78 » 11 Oct 2014, 18:32
Yes in fact i masked a very large part of function of the full patch that you can easily understand the concept.
initially this patch is a polyphonic patch and try to reproduce a piano damper pedal system.
So when you activate send switch all the time the hold switch has the same utility than a piano pedal.
joffo78
Unread post by joffo78 » 11 Oct 2014, 18:37
enjoy to have news after your rehearsal
