is it possible to enter data "exactly" (by typing) in the grid automation window? I need to automate patch parameters with exact numbers,
and avoid the stepping of the sliders. I have narrowed down the min/max of the parameters and used a large slider but i need exactitude.
grid question
- nay-seven
no, you can't use keyboard,but if you don't have too much values, you can try to insert an other fader and a mapper data..?
