synchro problem
Unread post by SylvainT » 09 Sep 2014, 09:23
Hello everybody
I found a strange problem.
I make some polyrhythm stuff. For that, I use master synchro and local synchro in sub patch, to create for example a box in 2/2 and another one in 3/2, but both working together with the same tempo.
I done that often with Usine V5 and it worked fine. But with Hollyhock, it's synchronised at the beginning but it became more and more shifted.
What the problem? A bug?
Thanks for answer.
All the best
P.S.: I made the same simple patch on Usine5 and Hollyhock. Works fine on V5 and not on Hollyhock.
Unread post by nay-seven » 09 Sep 2014, 10:04
if you think you found a bug, please use the bug report page and provide your patch
