Page 1 of 1
Posted: 29 Jul 2014, 18:46
by sephult
I am using the mouse XY for a reading into a fastscript and I am having oddities.
The question I have is:
Has anyone read the XY of a device such as the Matrix successfully into a fastscript, or have any examples?
I notice everytime I try to fTrace the value the CPU grows and remains even though the engine is stopped. The only way is to remove the trace. ( I am thinking I am running into a bug, maybe overloading the trace). However I can remove the trace from the script and not touch the contents of the trace display and the CPU goes back down.
-S
Posted: 29 Jul 2014, 20:07
by sephult
The CPU problem looks to be a receiving array and script out on my end, so I think I am the bug :cool:
Posted: 29 Jul 2014, 20:33
by sephult
I found my problem and possibly a bug in the FastScript Callback.
The Callback will trigger with disregard to the initialized parameter MIN/MAX.
This causes a constant trigger.
-S
Posted: 03 Aug 2014, 15:34
by senso
yes see my comment in the bug report
senso+++
