display in Hexadecimal !
Unread post by oli_lab » 09 Jul 2014, 01:10
Hi all !
I know that one is a far cry, but would anyone had already made a script that translate decimal numbers into HEX?
I'm experimenting with RFID tags...
thanks
caco
Unread post by caco » 11 Jul 2014, 22:11
How about this? Note that it will round your input down to an integer prior to the conversion to hex so you may lose some precision..
Code: Select all
// Int to Hex
// Paramters declaration
var input : Tparameter;
var output: Tparameter;
// initialisation procedure
procedure init;
begin
 input := CreateParam('input', ptDatafader);
 SetIsOutput(input,false);
 SetMin(input, 0);
 SetMax(input, 2048);
 SetSymbol(input,'');
 SetDefaultValue(input,10);
 SetValue(input,10);
 output := CreateParam('output',ptTextField);
 SetIsInput(output,false);
 SetMin(output,0);
 SetMax(output,100);
 SetSymbol(output,'');
 SetDefaultValue(output,10);
end;
// Global Variables
var inval : single;
// Main Loop procedure
begin
 inval := getValue(input);
 setstringvalue(output, IntToHex(Trunc(inval)));
end;
Unread post by oli_lab » 12 Jul 2014, 11:17
Thanx 0xFFFF times !
Now I can display the RFID tag in HEX, just like on my phone !
Those RFID Tags will be used to change patches and preset in Hollyhock
Code: Select all
// Array values (INTEGERS) to HEX commaText
CONST MAX_ITEMS = 8;
var ArrayIn, CommaOUT: Tparameter;
var SL1: TstringList;
procedure init;
var i: integer;
begin
  SetModuleColor($808080+302060);
  ArrayIn:= CreateParam('ArrayIn', PtArray);
  SetIsOutput(ArrayIn,False); SetMin(ArrayIn,0); setMax(ArrayIn,MAXINT);
  CommaOUT:= CreateParam('CommaOUT',PtTextField);
  setisINPUT(commaOut,false);
  SL1.create;
END;//INIT
var i, L: integer;
var s : string;
begin
      if (n=ArrayIn)
      then begin
         SL1.Clear;
         L:= getLength(ArrayIn);
         if L< MAX_ITEMS
         then begin
            For i&#58;= 0 to L-1
            do begin
               s &#58;= IntToHex&#40;trunc&#40;getDataArrayValue&#40;ArrayIn,i&#41;&#41;&#41;;
               SL1.add&#40;s&#41;;
            end;
         setStringValue&#40;CommaOut,SL1.GetCommatext&#41;;
       end;
      end;
END;//CB
Procedure Destroy;
begin
SL1.free;
end;
