Page 1 of 1
Posted: 08 Jul 2014, 21:13
by woodslanding
In this wkp, I have had trouble getting the matrix values to be saved. I have to change the values of one of the text fields FI for the values to be saved.
Perhaps it's a problem with the script. But it seems unlikely, as otherwise save and recall are working fine.
Well, not completely. I've also found that if I take an existing preset and edit it, and then save it under another preset number, it also overwrites the original patch. So I have to save a patch to a new slot before doing any editing to avoid losing work.
Again, could be a problem with my script??
BTW, this is a patch to figure out pedal steel tunings, in case you are wondering!
http://www.sensomusic.com/forums/upload ... KeyCtl.wkp
thanks,
-e
