Posted: 18 Mar 2014, 23:01
Sorry for replying to a closed forum section. I'd like to continue the discussion in this new thread:
Anyway, this is the essence of what I would like to accomplish. I realize this is a simplistic use of Usine, but unless I can get the basics down, improvement will be an uphill battle and it just won't be fun anymore:
I have one MIDI keyboard controller that I want to use. It's sending on Channel 1. I have let's say 3-6 racks each containing a VSTi. I want to be able to selectively enable/disable MIDI mute at the beginning of these racks (or inside the VSTi patch). This would allow me to selectively control the flow of data to each of the racks. So, I could play notes on the keyboard and have any combination of these racks receive the data. This will allow me to build interesting layers live. I would use this technique in conjunction with MIDI hold buttons (like in my MIDI Hold - noob patch post ) so I can suspend pads and release them at will.
I had tried something similar to ceaseless's 2nd paragraph, but I had some trouble killing notes that were held after I selected mute I.e. not even toggling my hold pedal would kill them). I'd post a diagram but I'm away at the moment.
I've entertained the idea of using different channels, but I'm not sure I need to complicate it that way. Any other thoughts before I dig in again tonight would be really appreciated.
nay-seven wrote:the devices in Usine are also patches, so you can create a mute switch directly in the device..?
BTW, this forum is closed so please use the suggestions forum
I tried using your patch nay-seven and it works great, but wouldn't that affect all racks that utilize that MIDI device? I should have tried it last night, but I got too tired. Also I noted that you used a data flux module (Stop) in combination with a MIDI object and I though that was some kind of bad no-no....like crossing the streams of a Proton Pack or something ...so it hadn't occurred to me to use it in that way.ceasless wrote:Also, if you want the mute button to be available to all workspaces, add it to the made control panel (one place on your interface for all) or set up a data bus and have mute buttons on every rack that send to that data bus. I think the first option is much saner.
Or you can build a sub patch for adding the mute option on each rack. Then you can affect which racks actively receive input from the keyboard without affecting the keyboard's effect on other racks. You can also add the 'mute', 'solo', etc buttons from your keyboard as inputs and outputs on this sub-patch. Then just use this sub-patch wherever you would normally use a midi in.
Hope it helps.
