TouchOSC with local feedback off and OSC lister : doesn't work
La Tenaille
Unread post by La Tenaille » 05 Mar 2014, 14:49
I've tried configuring TouchOSC buttons with local feedback off but the OSC lister module doesn't receive the changes. I was forced to create an OSC receive module per button (using the receive pin). Do I miss something ?
Other question : how do I configure the OSC receive module with more than one data ? Because only one OSC adress can be input for the whole module, so I have only the data 1 pin receiving...
Unread post by nay-seven » 07 Mar 2014, 11:20
can you precise the "local feedback off" ..?
about the OSC receive module, lets say you receive an xy with this address:
/4/xy-01
/4/xy/02
in the OSC receive module ( 2 data's) use the address
/4/xy
La Tenaille
Unread post by La Tenaille » 07 Mar 2014, 23:11
"local feedback off" means the touchOSC control (a switch lets say) sends the message, but the visual feedback is given by the target (from Usine). Usefull to be sure the tapped button has activated the target. But it seems I need to use the receive pin rather than the data in pin for this feature.
I'll try the receive module with your tip.
