Posted: 19 Nov 2013, 17:40
Hi all.
I tried to build a patch to control the pitch of a sampler with a knob and a sequenced line (or a curve).
I built 3 options :
1 - UP. the min value is the current value of the knob and the max is 24
2 - DOWN. the min is the current value of the knob and the max is -24
3 - NO. Curve or sequenced line not playing because it just play until the end or i use the knob.
Everything works fine, when i use knob the curve stop playing, when i press UP or DOWN the pith is going on.
But i can't find a way to transmit the current curve value to the knob and when the curve finish to play, the pitch is +24 semi tone and suddenly return to the current knob value (for exemple -3)
i upload my patch, because it seems more complex to tell than play.
I have the sensation that i build a more complex than necessary patch ...
Use knob and Lines to control pitch
I built 3 options :
