Audio out added to racks automatically
seamus
Unread post by seamus » 12 Oct 2013, 15:05
I have a problem that whenever I load my workspace my racks an audio out is added automatically even though I do not wish it to be added.
My racks are setup to feed into each other in a chain with only the final output going to my soundcard.
Is there a way to change this behavior. ? This is in the latest 64 bit version of hollyhock.
Unread post by nay-seven » 12 Oct 2013, 16:30
you're right
we 'll check this issue
joffo78
Unread post by joffo78 » 12 Oct 2013, 17:09
What happens if you disconnect your soundcard on this main device (named out 1)
And you create your own one ?
seamus
Unread post by seamus » 13 Oct 2013, 05:09
Ok something to try
seamus
Unread post by seamus » 19 Oct 2013, 05:19
Joffo's suggestion does fix the problem temporarily but it seems as if it is a bug. Default audio out should not be automatically added if the workspace is not saved that way. I made a custom audio out and bypassed the default one for now.
