matrix combobox?
Unread post by woodslanding » 15 Jul 2013, 20:04
Wondering what's involved in updating from v5.... I replaced 'result' in the script, but there is a lot of IML, which is not supported in HH?
Thoughts?
Unread post by senso » 15 Jul 2013, 20:59
the IML is implemented in HH just few changes in the declarations.
you have to replace SendInternalMsg by SendInternalMsg1, SendInternalMsg2, etc according the number of parameters.
senso++
Code: Select all
  SendUsineMsg (msg:string);
  SendInternalMsg1(msg:string);
  SendInternalMsg2(msg,arg1:string);
  SendInternalMsg3(msg,arg1,arg2:string);
  SendInternalMsg4(msg,arg1,arg2,arg3:string);
  SendInternalMsg5(msg,arg1,arg2,arg3,arg4:string);
  SendInternalMsg6(msg,arg1,arg2,arg3,arg4,arg6:string);
  function GetVariableString(name:string):string;
  function GetVariableInteger(name:string):integer;
  function GetVariableFloat(name:string):double;
Examples
  SendInternalMsg2('SET_TARGET_PATCH','SENDER_PATCH');
  SendInternalMsg4 ('GET_VALUE',GetStringValue(Input1),GetStringValue(Input2),'THEPARAMVALUE');
  SendInternalMsg3 ('SET_VALUE','PARAM','1','THEPARAMVALUE');
  SendInternalMsg4('SET_VALUE',GetStringValue(Input1),GetStringValue(Input2),FloatTostr(GetValue(Input3)));
Unread post by senso » 15 Jul 2013, 21:05
the script engine will be at least 5x faster in the next release.
Unread post by 23fx23 » 15 Jul 2013, 21:15
good news :)
Unread post by woodslanding » 15 Jul 2013, 22:16
awesome, thanks!!!
hmmm...... I guess the new engine doesn't support overloading the constructor??
