Posted: 15 Jul 2013, 20:04
Wondering what's involved in updating from v5.... I replaced 'result' in the script, but there is a lot of IML, which is not supported in HH?
Thoughts?
Thoughts?
Code: Select all
SendUsineMsg (msg:string);
SendInternalMsg1(msg:string);
SendInternalMsg2(msg,arg1:string);
SendInternalMsg3(msg,arg1,arg2:string);
SendInternalMsg4(msg,arg1,arg2,arg3:string);
SendInternalMsg5(msg,arg1,arg2,arg3,arg4:string);
SendInternalMsg6(msg,arg1,arg2,arg3,arg4,arg6:string);
function GetVariableString(name:string):string;
function GetVariableInteger(name:string):integer;
function GetVariableFloat(name:string):double;
Examples
SendInternalMsg2('SET_TARGET_PATCH','SENDER_PATCH');
SendInternalMsg4 ('GET_VALUE',GetStringValue(Input1),GetStringValue(Input2),'THEPARAMVALUE');
SendInternalMsg3 ('SET_VALUE','PARAM','1','THEPARAMVALUE');
SendInternalMsg4('SET_VALUE',GetStringValue(Input1),GetStringValue(Input2),FloatTostr(GetValue(Input3)));
