Is there a way to change the name of a script??
thanks,
-e
edit script name?
I found out how... It's a bit cumbersome, as you have to open the script editor and use "save as script" from the context menu. Alt-clicking opens a text input box, but whatever goes in there is added to the script name instead of changing it.
okay, that works. Not that cumbersome, and good to have my scripts stored anyway.
certainly a bug, but, actually, you can also Alt+click directly on the module for same result, without opening the editor..?
Users browsing this forum: No registered users and 38 guests
