Page 1 of 1
Posted: 19 Sep 2012, 23:13
by Ariajazz
Hi all you guys.
USINE is able to do whatever you can imagine, I believe that. Now my question is:
Is there any way to automatically decrease an audio signal gradually from a given level to a lower one like a fade out with a 10 seconds of fade???
Probably using a counter an a fader together. Have no idea how to do it. Any help will be highly appreciated
Posted: 20 Sep 2012, 01:05
by joffo78
Hello.
I think i found a good solution :
http://www.sensomusic.com/forums/upload ... 0level.jpg
It's a little tricky but seems powerfull.
Look at the workspace :
set next level
Posted: 20 Sep 2012, 01:13
by joffo78
I add some module if you want to modify the playing level :
download
Posted: 20 Sep 2012, 03:46
by Ariajazz
Thanks a lot for your reply. This is what I've done so far however some modules are not exactly the same such as the crossfade one since I can't find the one you used. I'm using USINE 5.20
I don´t know exactly how it will work, I asume that by pressing the GO buttom will do the fade. How do I control the duration of the fade out????
You will see that the incoming signal comes from the Amp sim AT3 outputs and the output of this patch is mono not stereo as you describe in your example. I'm a little confuse since this patch is a little tricky. I'd like you to clear things a little bit. The intention is to produce the fade (10 seconds duration) by a press of a button.
THANKS
Posted: 20 Sep 2012, 03:55
by Ariajazz
http://sensomusic.com/forums/uploads.ph ... volume.JPG
above is the link of the image for the patch I made. For some reason I can't upload it
Posted: 20 Sep 2012, 07:32
by Ariajazz
I think I have a solution. I found a vst plugin called FADERRATIC which does the job automatically and much easier. Thanks anyway for helping
Posted: 20 Sep 2012, 14:28
by joffo78
Ok.
if you are working in mono, you don't have to connect anything on all the inputs on the right.
thats all.
the fader called "time" is there to set the time of your fade.
Using vst plugging is a good solution but if you want to share it with another pepole.
Posted: 21 Sep 2012, 03:04
by Ariajazz
FADERRATIC did not work as I spected and the patch you posted does not work at all. I don´t know if I'm doing something wrong. I've checked everything several times and seems ok. Simply it does not do nothing. I'm jammed.
FADERRATIC can be found at:
http://www.delamancha.co.uk/faderratic.htm
Posted: 21 Sep 2012, 08:03
by nay-seven
Last workspace from joffo works for me
here an other version, mono and with a reset button , you can edit duration in seconds and minimum out
Download
Posted: 21 Sep 2012, 18:24
by Ariajazz
Nay seven Thank You so much it is exactly what I need. You read my mind friend. It also has a XY curve pad for accuracy. Just tested in my laptop and it works. Only need to try it in my main DAW pc within USINE workspace. This is for live use so I believe I just have to replace the sampler for an input source. Am I right?
Posted: 21 Sep 2012, 18:27
by nay-seven
yes, you're right
Posted: 21 Sep 2012, 20:23
by joffo78
In you're solution nay ,the starting level isn't the actual level isn't it ? it's always start at 0db ?
Posted: 21 Sep 2012, 21:15
by joffo78
What do you think of my solution that allow you to set volume & pitch with time fade :
http://www.sensomusic.com/forums/upload ... 20time.pat
Image ?
Posted: 21 Sep 2012, 22:54
by nay-seven
your patch is quite cool joffo, but not the same use..?
ariajazz was looking for an automatic fade, so if he need change the gain he can do it before the fade..so yes my solution is always 0dB at first .
Posted: 22 Sep 2012, 00:11
by joffo78
Ok.
I'm always preocupated by specificities of my job.
time management is a little different...
Posted: 22 Sep 2012, 08:56
by nay-seven
no problem joffo
And your constant research gives the community some good tools !
