Posted: 21 Mar 2012, 05:38
I'm new to Usine(couple of weeks now). Great program. Really enjoying it. After 5 years in SM, it's a nice change.
Got a nasty problem though. All the VST Plug in tests I've made so far fail my timing tests in host(FL Studio).
SO before I start uploading my "clocks" for you to look at, I decided to try some stock usine modules.
I started with the "Bassliner" module. I did nothing to it. Cut a vst plug in(with usine and Easine) and I get the same
results. Timing is way off, and it's drifting.
Is there a module in Usine that offers 100% accurate timing?(or a example somewhere)
Does Usine have any known timing issues?
Does usine have any known issues with FL Studio?
Note: all my clocks miss the first note in host-still working on that.........
Note: using latest versions of Usine and Easine.
