Hi
i did a vst plugins whitch control resolume by osc
the patch works (when i use it in usine vst instance) but i send anything when i use it in vst version.
osc doesn't work with vst export
- nay-seven
i just built a vst sending OSC to reaktor without problem, maybe the problem is on an other side..?
- senso
maybe check your firewall?
your host is probably blocked?
- nay-seven
i made my test with Easine and Easine has a OSC menu.([Ctrl+F10]
