Usine UI not reacting if Mixer Output Object is controlled by OSC
lalo
Unread post by lalo » 06 Sep 2011, 11:37
Hi guys,
i'm controlling the volume sliders and mute buttons of Usine with my TouchOSC patch.
i've connected my OSCreceive modules to several Mixer Output objects.
Everything works fine via OSC.
But if i try to interact with the screen controls using my mouse i am able to switch on/off the mute buttons, but the volume sliders does not move anymore.
any idea?
thanks
alfonso
Unread post by nay-seven » 06 Sep 2011, 11:50
yes, add a pass only if change module between your OSC module and the fader inlet
cause in your case, the OSC module is like a "master " on the fader
