Overlapping sounds with Sampler
Vincent
Hi all boiling brains and running fingers!
I want a Sampler to play long tracks and being able to overlap them (so, Poly is not set to 1).
It's in a track and a User Curve selects the Num value.
At each change of that value, a Has Changed module triggers the Play button.
The only thing connected to the Stop button is a LogicalMath checking if Synchronize is ON and stops only if ON goes from 1 to 0 (also with a Has Changed module).
Works fine (even if it's not so easy to draw the curve right in tempo), but...
When file#2 starts, file#1 just stops. No overlapping.
I've tried different combinations... and found no solution.
I'm sure an expert could in two seconds (well, less than one second, OK).
And, maybe reveal it to me?
Or should I do that with an almost empty and very long Piano Roll instead of User Curve?
Thanks!
Thanks!
- senso
It's normal,
No overlapping is possible with a single sampler.
when you change the NUM param the current polyphony is set to zero. (the sound stops)
To do the job you need 2 or more samplers (layers)
Vincent
In fact, as sampler, I only know GigaStudio and Kontakt...
I'm not an expert in all those machines, but it seems to me that this sampler is most a sort of expander, right?
You cannot build an instrument with it, with one (or velocity layers of) sample(s) per note - or it will be monophonic.
Since Kontakt may be plugged in Usine (and, as I still don't know precisely, Giga VI)(and it's also easy to build one in Reaktor), it's perhaps not useful to have a real sampler module...
- senso
You found my real motivation.
"why spend hours to develop a supra-giga-sampler, if it still exist?"
"Could I make a better reverb than Altiverb?"
"why turn Usine into a modular synth, if you can use Reaktor almost like a native Usine Module?"
The sampler module is the best illustration: It does exactly the opposite of what a "normal" sampler can't do... (random, absurd combinasions of pitch and reverse,etc.)
If you need a conventional sampler I think that it is much more efficient to use Kontakt or Giga.
PS: Kontakt works perfectly with Usine (I use it a lot).
Vincent
You mean "the opposite of what it can do", or "exactly what it cannot do", right?senso wrote:opposite of what a "normal" sampler can't do
I fully agree.
I don't like very much Kontakt, I won't use it (by the way, I don't have it) for simple things like just playing wave files... Your Sampler is perfect.
- senso
yes right 'can do'
sorry for the typo
The Usine sampler seems to do a good job for live music.
sorry for the typo
