Posted: 16 May 2011, 15:01
I tray to make crossfade playback with to samplers. This is how I imagine:
There is S1 and S2. When S1 "pos" reach 70% it trigger S2 + crossfade module's "cross" fader. And the same with S2. This is circuit between two samplers.
1. problem is that I don't now how to trigger "play button" without mouse or keyboard? I can only switch on or off playback, but switch does not work, because it happens when S1 start, S2 stop at 70% and inverse S1 stop when S2 starts.
2. Maybe true mathematical problem - haw to make event flow from 70%-100% equal to event flow from 0.1 - 1.0?
[This I need for crosfader. There is wire from samplers increasing "pos" to crossfader "cross" and between them "stop event flow". Event flow start passing only when 70% are reached.]
Can anyone help me with this? Is this practically possible? Or is there better crossfade playback method?
