Page 1 of 1
Posted: 10 May 2011, 08:14
by woodslanding
I have a problem--every time I add a second grid line to a track, and set it to 'ALL' mode, the setting of the ALL switch is not saved, and the track is back in GRID mode when I reopen it. I've just switched this setting, saved, reopened, and switched it again three times with my current WKP. And I've had this problem many times before.... eventually it seems to 'stick', and I never know what I did to make it stay.
Anyone else have this problem?? Am I missing something?
eric
Posted: 10 May 2011, 09:04
by nay-seven
can't reproduce..
can you try to built a workspace only with Usine sounds and patch to illustrate this..?
Posted: 10 May 2011, 11:11
by woodslanding
well, if it doesn't happen to you, then it's probably some wierd quirk in my wkp! I'll see what I can figure out.
