Page 1 of 1
Posted: 13 Apr 2011, 18:20
by joffo78
Hi
Nobody on the french forum to help to resolve my problem ?
I'll try to explain it here.
I'd like to convert pitch data in time data.
i can modify the pitch with positive negative or 0 values (0 mean no pitch so 100% of the duration of my sample)
I'd like to deduce the operator which permit me to calculate the duration of my sample when i modify the speed.
thank you.
Jof
Posted: 13 Apr 2011, 21:47
by nay-seven
sorry, was dreaming during maths lessons..
any maths guru for joffo..?
Posted: 13 Apr 2011, 22:43
by 23fx23
mmm speed double and length reduce of half when pitched an octave (+12),
so if not wrong should be len= original len / (pitch/6) maybe.
Posted: 13 Apr 2011, 22:44
by bsork
I was sure I had brought up this issue once, so I did a search and found this thread from 2006. You'll find the formula there.
Posted: 14 Apr 2011, 07:16
by joffo78
ok thank you
this formul : original_length / 2^(pitch/12) = shifted_length
seems interest me but i don't know what the symbol ^ means...
and how can i apply this formule in usine ?
Posted: 14 Apr 2011, 08:43
by caco
^=power.
It's in the maths section of the browser as A ^ B (power)
Posted: 14 Apr 2011, 10:53
by joffo78
thank you :)
Posted: 14 Apr 2011, 11:06
by joffo78
So i tried to traduct this : 300 / 2^(7/12) = 200.225978126 in usine language without success :(
may i did some mistake ?
Posted: 14 Apr 2011, 11:23
by nay-seven
here it is : ( when there's parenthesis...)
Posted: 14 Apr 2011, 11:29
by senso
@bsork: you're the Usine's encyclopedia!
Posted: 14 Apr 2011, 12:01
by joffo78
thank you you're masters !
Posted: 15 Apr 2011, 09:24
by joffo78
So Nay you're not so bad in math.No more than me !
