Posted: 05 Mar 2011, 09:47
Hi all,
I've got a problem with a patch and I need help. I can't figure out where's the problem.
I built a patch that allows me to store and recall presets according to a selected item in a list. This is not simply based on the list index, but on the text itself. The idea is to be able to change the order of items in the list and keep the preset associated. My goal is to store in a preset all the parameters linked to a sample in the sampler file list.
My patch is based on a script. I tryed several things, but the easiest and most effective way I've found is by using comma separated text and TStringList. If someone have a better idea...
In facts, my patch works A1... as long as I don't save and reload the workspace. Then, the script only recalls the first 8-10 elements saved in the comma text list. And I can't figure out why...maybe it's simply a Usine bug. Maybe the comma text I try to save is too long for a ptTextfield.
So, I've prepared an exemple patch :
preset_manager.pat
And here is the script :
preset_manager.pat
Code: Select all
// parameters declaration
var inPresetName : Tparameter;
var inStore : Tparameter;
var inRecall : Tparameter;
var inCleanup : Tparameter;
var inClear : Tparameter;
var inCommaList : Tparameter;
var presetsComma : Tparameter;
var filesList : TStringList;
var presetsList : TStringList;
procedure init;
begin
inPresetName := CreateParam('preset name',ptTextfield);
SetIsOutPut(inPresetName,false);
inCommaList := CreateParam('comma text',ptTextfield);
SetIsOutPut(inCommaList,false);
presetsComma := CreateParam('preset comma',ptTextfield);
SetIsOutPut(presetsComma,false);
SetIsInput(presetsComma,false);
SetDontSave(presetsComma, false);
inStore := CreateParam('store',ptButton);
SetIsOutPut(inStore,false);
inRecall := CreateParam('recall',ptButton);
SetIsOutPut(inRecall,false);
inCleanup := CreateParam('cleanup',ptButton);
SetIsOutPut(inCleanup,false);
inClear := CreateParam('clear',ptButton);
SetIsOutPut(inClear,false);
filesList := tStringList.create;
presetsList := tStringList.create;
presetsList.capacity := 64;
end;
Procedure savePresets();
begin
setStringValue(presetsComma, presetsList.commatext);
end;
Procedure clearPresets();
var x:Integer;
begin
strace('Clearing presetsList');
presetsList.clear;
for x := 0 to 63 do begin
presetsList.add('free');
end;
savePresets();
end;
Procedure loadPresets;
var x:Integer;
begin
strace('Loading presetsList.');
presetsList.commatext := getStringValue(presetsComma);
if presetsList.count = 0 then clearPresets();
end;
Procedure cleanupPresets();
var x:Integer;
begin
strace('Clean up');
filesList.commatext := getStringValue(inCommaList);
for x := 0 to presetsList.count do begin
if filesList.indexOf(presetsList[x]) = -1 then begin
presetsList[x] := 'free';
end;
end;
end;
Procedure recallPreset(presetIndex:Integer);
var pmName:String;
var pmNum:String;
begin
pmName:= 'Preset' + intToStr(presetIndex div 16 + 1);
pmNum := intToStr(presetIndex mod 16);
SendInternalMsg('SET_TARGET_PATCH','SENDER_PATCH');
SendInternalMsg('SET_VALUE', pmName, 'num', pmNum);
end;
Procedure storePreset(presetIndex:Integer);
var pmName:String;
var pmNum:String;
begin
SendInternalMsg('SET_VALUE', pmName, 'store', '1');
end;
var x:integer;
var pmName:String;
var pmNum:String;
var presetIndex:integer;
begin
// Store
if (n=inStore) and (getValue(inStore)=1) then begin
if presetsList.count = 0 then loadPresets();
presetIndex := presetsList.indexOf(getStringValue(inPresetName));
if presetIndex = -1 then begin
presetIndex := presetsList.indexOf('free');
cleanupPresets();
end;
presetsList[presetIndex] := getStringValue(inPresetName);
end;
storePreset(presetIndex);
savePresets();
end;
// Recall
if (n=inRecall) and (getValue(inRecall) = 1) then begin
if presetIndex <> -1 then begin
strace('Recalling');
recallPreset(presetIndex);
end;
end;
// Clear
if (n=inClear) and (getValue(inClear)=1) then begin
strace('Clear');
clearPresets();
end;
// Cleanup
if ((n=inCleanUp) and (getValue(inCleanUp)=1)) then begin
cleanupPresets();
end;
end;
// main proc
Procedure Process;
begin
end;
