I must be doing something wrong. I cannot get the receive midi clock patch included with the latest Usine to work.
I have connected all 5 midi "in" to my midi input and turned the patch on but no go. If I use the older version of the receive midi clock patch it works.
Am I missing something?
receive midi clock
Floego
what about the console? can you see some midi activity on it?
- senso
maybe the "ignore time clock" in the setup is activated?
gurulogic
No, it is not.senso wrote:maybe the "ignore time clock" in the setup is activated?
Ok, I'm a little rusty right now but if I am correct I should be able to load the Receive MIDI Clock sub patch into a patch and connect the midi out from the midi input module to all of the midi inputs to the patch and fully control Usine via remote transport and remote tempo, correct? All I am getting is remote transport.. and this is definately not a problem of my external gear not sending clock. Everything else is working fine from the same clock, but I can't help but think I am doing something wrong if no one else has this problem..?
