Why i have this error message each time i open this workspace ?
Error Message :
[1] Error:Process msg Out of memory
[2] Error:Internal in Process msg
[3] Workspace C:Program FilesUsine 5FilesWorkSpace.wkp loaded
You can download my workpace here (There is no plugins need)
Error Message in Console
multiphone
Hello cmodica,
I have take a quick look to your workspace, realy nice idea.
But...
The max rec time value of your recorder is set on 1200s (So 20') maybe is an extreme value compared as the real time value of your recording ? This value increase directly the value of the memory needed by Usine. Try to decrease this value and save your patch.
Maybe i'ts a way.
On my configuration your patch work well.
Best
But...
Maybe i'ts a way.
Best
Floego
I downloaded and open your workspace into Usine and got no error messages.
Could you post your Console view right after you load your workspace? Maybe it should help.
- nay-seven
have you check the dir you use to record in your setup /preference..?
maybe not enough space..?
just a thought..
don't have any problem when i open it..
just a thought..
- cmodica
Thank you very much all.
You are right Multiphone. I decrease the MaxRecTime Value and the error messages desapear
It is great
It is great
