Page 1 of 1
Posted: 07 May 2010, 20:01
by lucenay71
hello,
I use to insert native Absynth in usine and everything is doing well. But I'm a beginner with Reaktor and I cannot obtain any sound when I patch it in Usine. I do the same as my absynth patch and it doesn't work with the reaktor patch. Is there somebody who can help me ?
Thanks a lot
Posted: 07 May 2010, 20:15
by nay-seven
i don't have Reaktor myself ( except a free reaktor session one ) but i know that senso use it and don't have any problem..
maybe a screen shot of the way you patch it..?
Posted: 08 May 2010, 09:42
by woodslanding
yes, i use reaktor as vst inside usine all the time, and no probs.
What ens do you have loaded into reaktor? Make sure it uses the same outs you are patching from in usine.....
