how to communicate with the bypass from the rack mode
manecante
Unread post by manecante » 11 Dec 2009, 04:45
Is there a possibility to communicate via a module with the bypass from the rack mode/all mode in order to get and to send its state ?
Unread post by nay-seven » 11 Dec 2009, 07:20
you can use this method :
create a new patch in your rack and create this :
( message is set to control change )
make a midi learn on your bypass with this ...?
you can also try a switch on a "patch active " module..?
Unread post by senso » 11 Dec 2009, 22:37
just for info, will be able in the V5.
