how to communicate with the bypass from the rack mode
- nay-seven
you can use this method :
create a new patch in your rack and create this :
( message is set to control change )
make a midi learn on your bypass with this ...?
you can also try a switch on a "patch active " module..?
- senso
just for info, will be able in the V5.
