How to convert values from 0 to 1 with values ranging from 0 to 127 ?
marcelvincent
Unread post by marcelvincent » 24 May 2009, 14:58
I do not find out which module to use to convert values from 0 to 1 with values ranging from 0 to 127. I tried with the mathematics modules but without success.
It must be very simple but I can not find. :-(
Try to make a Usine patch for my sound table !
Unread post by 23fx23 » 24 May 2009, 15:30
there are severals methods, but the simplest must be just add a AxB module, link your input to A and set B to 127, then add trunc (booth math modules)if needed to keep only integer. Or there are several tools called "change scale" in data/data manipulation that will let you specify min and max.
marcelvincent
Unread post by marcelvincent » 24 May 2009, 16:09
Thank you for your help. everything is ok now.
Users browsing this forum: No registered users and 37 guests
